Lowering the Camaro, need oppinions...
Old May 8, 2007 | 04:50 PM
Need4Camaro's Avatar
Would it be safe to lower just the front of the car by 1 quarter of an inch to give it an aggressive stance while putting 17's up front and 18's in the rear? If not, would it be okay to lower the front by (if possible) 3/8's an inch upfront and 1/4th an inch in the rear with same wheel / tire option as listed above? Would I beable to run true duals like this?
Where can I find springs / struts / shocks to suite this?
Old May 9, 2007 | 12:46 PM
ConElite's Avatar
QA1 coil over kit for the front would be a good choice.
Old May 9, 2007 | 01:31 PM
Sam Strano's Avatar
How about 5/8-3/4" in front, about 1/2" in back? You can do that with Koni's, and get literally the best dampers around for the car at the same time (which only helps the ride, stability and handling.
Old May 9, 2007 | 02:23 PM
Wouldn't that make the rear lower than the front and make the car look somewhat awkward?
Old May 9, 2007 | 02:26 PM
Sam Strano's Avatar
I you lower the front more than the rear, how would it end up with the rear lower the front?
Old May 9, 2007 | 03:12 PM
Crap I read it wrong, I'm sorry...
Where can I find a kit like that? Any chance of scraping a true dual exhaust? would there be any ground effect clearence issues say I had them installed?
Old May 11, 2007 | 09:27 AM
al 96 Ram Air T/A's Avatar
Well, you can find a "kit" like that on my car. Or, you can buy one from Sam.
Old May 11, 2007 | 11:01 AM
teke184's Avatar
not really a "kit"
just a set of koni single adjustable shocks. put the front ones on the lower spring perch and then remove the spring isolator form the rear, and do the "hose mod"
do some searching
oldschool
Feb 9, 2016 09:21 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
