Lower ed, now need help w/ adj. PHR
Old Apr 24, 2004 | 08:15 PM
Bone Daddy's Avatar
Question Lower ed, now need help w/ adj. PHR
Now that all my parts are *cough* in the right positions, and the car is lowered and ready to go, how to I adjust my PHR to center my rear end? Mine you have to remove/adjust/install with each time so I would appreciate the best/fastest way to do it. Also, should I put my torque arm on first before the adjust? Or can I adjust the bar beforehand? (easier on me) Also I don't have LCA relocation brackets. (car won't be road worthy for a few months)
I appreciate any help.
Old Apr 26, 2004 | 12:20 PM
Bone Daddy's Avatar
Anybody know how to adjust this thing? Someone has to own a adjustable panhard rod in this crazy crowd, lol.
Old Apr 26, 2004 | 01:20 PM
LPEdave's Avatar
Here's what I'd do: Jack the rear up by the pumpkin, throw some jack stands under the axle. Measure how far you want to move the axle, and which direction. Unbolt one end of the Panhard bar, and shorten/lengthen it by the amount you want. Reattach it, recognizing that there will be some prying and what-not to get the axle or car shifted. Double-check your measurement, it's probably awefully close at this point.
Dave
Old Apr 26, 2004 | 02:01 PM
Bone Daddy's Avatar
So the point is to get the rear end level? I guess my question is how do I know how much I have to move the rear? Should I put a level on the axle tubes? I know how to move the bar in/out it's just how do I know where and how much to move it is the problem. The only reason I bought this thing was it was supposed to help with the problems associated w/ lowered suspensions. Thanks for all your help Dave, I appreciate it.
Old Apr 26, 2004 | 03:02 PM
LPEdave's Avatar
Ah. No, the idea is to get the axle centered under the car, left to right. So measure say from the ouside of the wheel to the fender on each side, to see how far the axle is shifted - then the panhard rod will let you shift the axle left or right.
Dave
Old Apr 26, 2004 | 06:21 PM
Bone Daddy's Avatar
Thanks Dave, I'll try and do it mid-week, then report back.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
