Low trac/ABS lights.
Old Apr 28, 2007 | 03:56 PM
PWR-TRIP's Avatar
When i'm driving normal and about to stop, my low trac light comes on and my brakes feel really wierd like i'm on ice or something and it takes longer time to stop. I don't have traction control on my 95 Z28. When i start my car, ABS light comes on. I started having this problem after i took her out from winter Hibernation (Never before) Anyone know how to fix this problem?
Old Apr 28, 2007 | 04:06 PM
JakeRobb's Avatar
Super Moderator
The "Low Trac" light comes on when the ABS system detects wheel slippage. The weird pedal feel is also a symptom of the ABS system engaging to minimize that slippage. If you're completely sure the wheels aren't slipping, then I would guess that something is wrong with one or more of your wheel speed sensors.
Does the ABS light come on and stay on, or does it come on for a few seconds when you start the car and then turn off?
Old Apr 28, 2007 | 04:18 PM
PWR-TRIP's Avatar
It stays on even after starting my car. Even when i'm driving.
Old Apr 28, 2007 | 04:33 PM
OBE1 95Z28's Avatar
Could be several causes. A dirty rear sensor is a common cause. Remove the ABS sensor from the top of the differential and clean it. Another cause could be a faulty front ABS harness due to exhaust heat.
Old Apr 28, 2007 | 04:40 PM
PWR-TRIP's Avatar
With what?
Old Apr 28, 2007 | 04:44 PM
OBE1 95Z28's Avatar
Always helps to look The sensor is held down with a small bolt.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
