LG's fbody to c5 brake brackets
Old Dec 14, 2004 | 03:11 PM
oldBones's Avatar
LG's brake brackets work with lt1 spindles?
Will the Lt1 spindle work with LGmotorsport C5 to Fbody brake bracket or will I need to get my hands on LS1 spindles? Thanks Cameron
Old Dec 14, 2004 | 03:40 PM
5.0THIS's Avatar
Re: LG's fbody to c5 brake brackets
They probably will, you'll just be cutting off more of the original spindle to make them work. (You'll be cutting off the bigger caliper mounting "ears")
Old Dec 15, 2004 | 09:56 AM
lateapex's Avatar
The mounting bosses are in the wrong location on LT1 steering knuckles. You would need LS1 knuckles to use the LG adaptor brackets.
Old Dec 15, 2004 | 10:19 AM
mitchntx's Avatar
100% correct
Old Dec 15, 2004 | 04:04 PM
5.0THIS's Avatar
Seems stupid to me that LG wouldnt make a bracket like yours that can work with either spindle
Old Dec 15, 2004 | 04:36 PM
CamaroSS30thAnn's Avatar
i was watching i horsepower tv about a week ago and they did a c5 brake conversion on a 96/97 LT1 SS and i dont remember them changing teh spindles, they just cut off the lower part of teh spindle and bolted up the brackets , it was a repeat btw
Old Dec 15, 2004 | 11:38 PM
Black_Z28's Avatar
I believe those were Baer brakes that they put on that SS. Which are actually just C4 brakes with the Baer name on them.
Old Dec 16, 2004 | 06:28 AM
oldBones's Avatar
The brackets I've got aren't fitting correctly I've removed .30 on one edge of the bracket and also the two of the fins on the caliper. The spindle has to be clearanced for the caliper about .20 and the two of the bolt hole need to be redrilled to match the size on the abutment bracket. I paid 250. for this brack if I had to do it again I'd use Bob Bishop's bracket. RRRRR
Old Dec 17, 2004 | 03:06 PM
i belive the brakes said "corvette" b/c my buddy asked me y they said corvette on them when they are going on a camaro, i told them they were doing a corvette upgrade
Fastbird93
Apr 9, 2016 07:01 PM
meissen
Jun 1, 2015 07:59 AM
Gtpguy
Jan 26, 2015 04:50 PM
Cam's maro
Jan 8, 2015 05:01 AM
