LCA's...why???
Old Jan 13, 2005 | 09:38 PM
LPE_wannabe's Avatar
Arrow LCA's...why???
my car is lowered but still has the factory LCA's...why is it recomended that aftermarket ones are installed after lowering??? thanks a lot!
Old Jan 14, 2005 | 06:37 AM
oil pan 4's Avatar
Re: LCA's...why???
I don't know if you are talking about frount or rear but most people just keep the stock ones. I don't think very many people change the out.
Old Jan 14, 2005 | 08:13 AM
383Z4ME's Avatar
Re: LCA's...why???
When you lower the body you lose some leverage. By lowering the control arm pivot point you regain that leverage. This helps plant the tires on sudden acceleration.
Old Jan 14, 2005 | 10:25 AM
97z28/m6's Avatar
Re: LCA's...why???
which is the bracket not the LCA
Old Jan 14, 2005 | 10:53 AM
Red96Lt1's Avatar
Re: LCA's...why???
I agree to most people not replacing the upper and lower a arms, but LCA's, come on. That is the cheapest traction mod.
Old Jan 14, 2005 | 11:28 AM
383Z4ME's Avatar
Re: LCA's...why???
Sorry. I mis-read. I don't think you need to replace the control arms unless you are making serious horsepower. Maybe 420+ rwhp. You could have a local welder box the factory piece pretty cheaply by welding a flat top on the U shaped factory ones. I think replacing the bushing with new poly ones is worthwhile as it tightens things up a little.
Rick
Old Jan 14, 2005 | 11:59 AM
Red96Lt1's Avatar
Re: LCA's...why???
I've seen someone that put a piece of 1" pipe inside of the u shape of the LCA and replaced the bushing. Thought it was a good idea. Makes it pretty heavy. My chromoly BMR LCA weighs less than the stock LCA, so doing the pipe method would be pretty heavy.
Old Jan 14, 2005 | 05:32 PM
Z95m6's Avatar
Re: LCA's...why???
I think its close to $80 for a set of poly bushings for our LCA's. You can get New aftermarket LCA's with poly bushings for around 100. Why make your own.
Old Jan 14, 2005 | 06:23 PM
Severous01's Avatar
Re: LCA's...why???
$80??? dude..you're gettin ripped...30-maybe
Old Jan 15, 2005 | 01:39 AM
Heatmaker's Avatar
Advanced Member
Re: LCA's...why???
Why???? Why not... those flimsy stockers are junk... upgrading your LCA's is a good way to plant your rear nicely. I went with Hotchkis when I did mine a while back... Nice heavy duty piece that I'm satisfied with... but these bad boys will give you one hell of a bumpy ride. There's some guys that sell the LCA's on ebay for a couple of bucks.. not bad either. Any how as someone stated earlier it's all about the Pinion angle. When you lower you car you can set the angle off.. the LCA bracts set the Pinion angle properly again.
Old Jan 15, 2005 | 08:37 AM
GCEZ28's Avatar
Re: LCA's...why???
Lowering your car upsets BOTH the control arm geometry AND pinion angle. Control arm relocation brackets will correct the control arm geomtry for straight line traction but will not correct the pinion angle. the only way to get the pinion angle where it should be after lowering is with an adjustable torque arm. Wrong pinion angle causes driveshaft misalignment stressing u-joints and possibly creating vibration.
Old Jan 20, 2005 | 01:57 PM
Re: LCA's...why???
is an adjustable torque arm the only way to fix the pinion angle? that bastard is $329 from thunder racing...should i just get the TRAK PAK cause it seems like a better deal and i was planning on getting SFC's any way??? thanks
Old Jan 20, 2005 | 03:53 PM
97FormulaWS-6's Avatar
Re: LCA's...why???
I believe the Trak-Pak is the unit that mounts to a cross-member and not the tranny; if so, yes, that is a better/safer unit that the Tranny mounted one. I should've gotten that one, but I can always sell my BMR "normal" TA for that one.
Old Jan 20, 2005 | 03:56 PM
383Z4ME's Avatar
Re: LCA's...why???
I vote for this one.
http://www.spohn.net/product.cfm?productid=1330
Old Jan 20, 2005 | 04:57 PM
Heatmaker's Avatar
Advanced Member
Re: LCA's...why???
How does the Track pak TQ arm mount? When I looked at the kit all I saw was bar... I was goign to get that... but It looked like a headache waiting...???
