LAkewood LCA Quality
Old Aug 10, 2005 | 09:31 AM
1quickTA's Avatar
I just picked up some Lakewood lower control arms and noticed that they seem to have some loose weld beads or random metal stuck in the main boxed tube that you can hear fall down as you turn the LCAs over. Anyone else have this issue? Think it will make much noticable noise when they are on the car or should I think about getting some different LCAs?
Old Aug 10, 2005 | 11:50 AM
NOSCaMaRo's Avatar
Re: LAkewood LCA Quality
Its probably metal shavings from when the holes were drilled then they got welded into the control arm. Lakewoods welds are Robotic I think
Old Aug 14, 2005 | 05:41 PM
1quickTA's Avatar
Aynone else had this issue? I had the shop order in another pair and they had the same issue so I am thinking about trying something different. Any suggestions for a good quality but relatively cheap LCA (thinking below $150)???
Old Aug 14, 2005 | 05:47 PM
Terran2k's Avatar
i think you'll be fine, dont see how you'd be able to hear it over the noise your car makes when its in motion anyway.
Hal Fisher
Sep 30, 2015 09:03 PM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 15, 2015 11:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
