Koni SA adjustment questions...
Old Oct 23, 2006 | 12:30 AM
SteveZ Z-28's Avatar
See suspension mods in sig...
I just put on some Koni SA's since I was unhappy with the ride of the Bilstein HD's... They seemed too soft and I was hitting the jounce bumpers on the rear axle a lot. So I purchased the Koni SA's so I could adjust my rear shocks. It seems like my right side is still bottoming out on the jounce bumper even after adjusting both sides up about 3/4 of a turn, but it's not as bad as it was with the HD's. Am I destined to bottom out on the jounce more because of the Prokit's or do you think that I can adjust most of it out by stiffening the shocks?
Also, if I wanted to check to make sure they were even pressure on both sides, can I adjust them both soft all the way and then come up an even amount of turns on each side? I won't damage the shock by turning them all the way soft (specifically, is there a stop when you shouldn't be able to soften them anymore), will I? I just assumed that they were even from the factory, but I would like to check.
Thanks!
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
