Just Installed New Rag Joint Eliminator (review)
Old Sep 19, 2007 | 08:48 PM
Sick97SS's Avatar
Lots of pictures + review
http://home.comcast.net/~nstama/ragjoint.htm
enjoy
Old Sep 21, 2007 | 03:42 PM
Bow94z's Avatar
good stuff, I always been meaning to pick one up cause my steering is sloppy, but now since my Strano Springs and Koni's are on their way, this was totally necessary to add to the mix...Did you get the rag join elim quickly inthe mail?
I think im gonna paint my shaft red too...
Steering shaft that is!
Old Sep 21, 2007 | 06:11 PM
Bud M's Avatar
You should get it quick, Jason at Unbalanced Engineering is good to deal with
Old Sep 21, 2007 | 10:08 PM
Sick97SS's Avatar
I got it 2 days after i ordered it. Can't belive i didn't get one sooner.
Old Sep 24, 2007 | 10:16 PM
mrz28 73/97's Avatar
Thanks for the heads up about this part and I just ordered it.
Old Sep 25, 2007 | 05:14 PM
1quickTA's Avatar
What is the point of the rag joint? Isn't it there so that your steering column will break in an accident rather than shoving the steering wheel/column into you?
Old Sep 25, 2007 | 09:46 PM
Sick97SS's Avatar
there are small plastic rivets that breakaway during an accident. you can see them on the top of the steering shaft in the second to last picture on my site. the ragjoint just dampens road vibrations and wheel-jerk from potholes and such. but after the install there are no vibrations in the wheel. no negative affects what-so-ever. all good in my opinion.
Old Oct 11, 2007 | 12:26 AM
LT1-TA's Avatar
WOW... i need one of these.. for $30 bucks? hell yeah!
Old Oct 16, 2007 | 10:37 AM
Bow94z's Avatar
Was it just me or did everyone with LT's have to cut two of the bolts cause it was hitting the header....
I couldnt turn them around since they were still too long
Old Oct 17, 2007 | 09:24 AM
al 96 Ram Air T/A's Avatar
My steering wheel is slightly off center. The car tracks straight, but the wheel needs to be a slightly off center for the car to stay straight. The alignment seems on. To center the wheel, would the adjustment be made during the replacement of the rag-joint?
Old Nov 6, 2007 | 06:19 AM
mehoffz24's Avatar
does any one know how to contact unbalanced engineering other than the email address on thier home page??? i ordered a rag joint elim on 10 21 07 and still have not recieved it!!!!! i have sent emails and have not gotten any response.. any help would be appreciated...
Old Nov 6, 2007 | 10:06 AM
Bud M's Avatar
No, it would be made at an alignment shop.
Old Nov 6, 2007 | 10:27 AM
88irocz28's Avatar
My 1994 TA has a little slop in the steering, presumably from the rag joint since the tie rod ends are new. It tends to wander all over the place with the wide 275 tires I am running right now. I suppose the rag joint eliminator kit should solve this issue to some extent??
Old Nov 6, 2007 | 04:29 PM
TobyZ28's Avatar
Not neccessarily.
Play comes from either A) Rod Ends B) Rag Joint C) Steering rack
You need to identify which it is. You've eliminated A, to determine if its the rack or rag join have someone wiggle the wheel (with the car on the ground, not jacked up) while you look under the hood. If its the rag joint giving you the play you will notice it right away, if the rag joint is moving as one piece it's either B or A, since you've eliminated A it must be B
I just replaced my steering rack (which had the play) and did the Rag Joint eliminator at the same time.
Old Nov 6, 2007 | 08:01 PM
mehoffz24's Avatar
sorry i got a hold of jason....thanks anyway
