Just got new adj. panhard rod, help with install....
Old Jul 27, 2005 | 11:19 PM
AlwaysCode390's Avatar
Question Just got new adj. panhard rod, help with install....
Hey guys, I dont even see my stock panhard rod under the car. Where do I look? I heard its only two bolts. Can I just take off the old one and bolt up the new one or is there anything I should do before I start taking off bolts? Is one end on the frame and one end touching the rearend? Why is it adjustable? What are you adjusting for? Thanks--- sorry for being such a newb---
Old Jul 27, 2005 | 11:35 PM
smoknta's Avatar
Re: Just got new adj. panhard rod, help with install....
Sorry...this may sound stupid. But why did you buy an adjustable panhard bar if you dont even know why it is adjustable?
Old Jul 27, 2005 | 11:52 PM
I was expecting that, it was a good deal ....do you know how to help me?
Old Jul 28, 2005 | 07:46 AM
2000GTP's Avatar
Did the rod come with instructions, if so, follow them. Also, you should look into getting a Chiltons manual or equivalent and that will familarize you with the various parts of the car and their locations. The adjustable panhard rod is useful if you are running oversize tires, like 315s. Adjusting the rod is kind of a pain, and it is outlined in some previous threads, so do a search to find it if your instructions dont outline the procedure. BTW, the panhard rod sits slightly in front of the rear axle at a slight diaganol.
Old Jul 28, 2005 | 08:10 AM
In this picture, its the black, tubular bar, running almost horizontally from a bracket on the driver's side of the rear axle assembly to a large sheet metal "arm" on the passenger side of the body.
http://cjcfo.fbody.com/members/injun.../DCP03637a.jpg
If you don't know why you are adjusting it, simply adjust it to match the length of your stock arm.
Old Jul 28, 2005 | 11:10 AM
Thumbs up Re: Just got new adj. panhard rod, help with install....
Nope , no instructions ..... but that doesnt look too bad to replace. I didnt even realize it was behind the differential, lol. My new one is SO much thicker, thanks guys!!!
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
