intermittent ABS light
Old Jun 5, 2006 | 10:54 AM
spyro_ss's Avatar
have a 95 TA. occasionally while cruising (not braking), the ABS Inop light comes on and the low trac and brake lights flash. after a minute or so, they all go out. brakes are good. any ideas?
Old Jun 5, 2006 | 11:47 AM
teke184's Avatar
Re: intermittent ABS light
ABS sensor connector on the axle is bad or loose.
check it first
Old Jun 5, 2006 | 01:47 PM
Coolformula's Avatar
Mine 94 car does this usually mositure gets in there..usually in a day its gone...and the ABS still works. or the 3rd brakelight is out.
Old Jun 5, 2006 | 09:06 PM
slp223's Avatar
i had the same problem with the rear axle sensor.
Old Jun 6, 2006 | 02:53 PM
OBE1 95Z28's Avatar
Those dash lights use a ground that's terminated on the passenger side inner fender, next to the red positive post. Common failure for this ground point to make poor contact and give you a "light show". Remove the ground stud and sand off the paint under the stud. Clean everything up and retighten.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
