Installing LCAs and PH Rod ?
Re: Installing LCAs and PH Rod ?
4 bolts on the LCAs and 2 on the PHB....
my stock bolts were 17mm i think, and the replacement ones that BMR sent were 18mm i beleive.
the LCA bolts are a little tricky to get to with a socket wrench...have an end wrench handy.
do one side at a time with the LCA, and a second person is helpful to move the axle if it shifts.
Originally Posted by Huntr1117
Should I jack the car up when I do it or not?
One thing to add to this, is DON'T fully tighten the bolts when you re-install them. You want the car's weight on the suspension when you torque the bolts all the way down; this helps the suspension move properly and helps prevent squeeks.
Just finished installing the LCAs and the PHR this morning. It was pretty easy, it just took me a while because my driveway is slanted and my car sits pretty low. Thanks for everyones help
The rear seems to be more stiff especially around corners. The overall ride quality seems smoother too. I haven't had a chance to get on it yet, so I don't know if it helped with traction or not. I think that it was money well spent.
Skull Leader
Aug 10, 2002 11:01 AM
