Installing LCA
Old Sep 19, 2004 | 04:34 PM
SnakeKilla's Avatar
Lightbulb Installing LCA
Just bought a set of BMR LCAs poly/rubber and I was wondering which end goes to the front. They are the non-adjs.
Old Sep 19, 2004 | 04:47 PM
NoFear95's Avatar
Re: Installing LCA
Doesnt matter. I like to read the lettering from the outside.
Old Sep 19, 2004 | 04:48 PM
simple's Avatar
Re: Installing LCA
if you bought poly/rubber, the rubber bushing goes to the chassis and the poly goes to the rearend, zerks facing the ground
the point of that is to have less road noise and vibrations on the chassis end with the rubber bushing but still retaining some of the stiffness with the poly bushing at the rear
Old Sep 19, 2004 | 04:56 PM
Z-RATED94's Avatar
Re: Installing LCA
Rubber bushing to the chassis, as simple stated. And yes, it does make a difference.
Old Sep 19, 2004 | 07:12 PM
NoFear95's Avatar
Re: Installing LCA
Sorry, didnt know they were different on each end. Strange.
Old Sep 20, 2004 | 08:27 AM
SnakeKilla's Avatar
Re: Installing LCA
Thanks for all your replies
I will go ahead and install them right away!!!
Old Sep 21, 2004 | 01:16 AM
LetMeBurnU's Avatar
Re: Installing LCA
Im thinking of getting me a set of BMR lca's and im going with the tubular ones. BTW there's two kinds..........poly/rubber and poly bushing what is the difference between the two? they're both tubulars. And how much do they usually run for? i see them for 109.00.
Old Sep 21, 2004 | 06:28 AM
Mtrhds94Z's Avatar
Re: Installing LCA
I paid 98.95 for the LCA's anbd 80.95 for a panhard rod[BMR's] from Thunderracing on one of their sales[that's 10% off]8/13/04..
Shipping was less than 13.00 and I had a few other small items in there too..
Watch the sponsors for sales, you can beat 109.00, that's for sure..
I think I saw 15% off recently also:
See:
http://web.camaross.com/forums/showthread.php?t=301973
Looked on their site.. don't see LCA's or PHR tho..
Old Sep 21, 2004 | 11:22 AM
Eddie95Z28's Avatar
Re: Installing LCA
The difference is that the poly/rubber has a poly urethane bushing on one end and a rubber one on the other. The poly/poly has poly urethane on both ends which is stiffer but transmits more road nois and vibrations.
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
Apr 30, 2015 03:43 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
