How to replace rear pads?
Does anyone have step by step instructions for replacing my rear brake pads.
I have a 3/8 hex drive for my breaker bar to remove the caliper, do the pads then just slide in or what?
I haven't seen a step by step tutorial except for the LS1 cars, and even then it was shotty in the rear area. I assume (from your sig) you have a LT1 car. If so, the pads are easy to change, cute-like even!! The caliper just opens up and the wee things pop out, they can be a pain to get re-fitted in the slots though. Basically the same method as the front, and only a tad bit different. Doesn't anyone own a haynes or chilton's manual around here? Maybe Xride and I should make a How-to about this after we do the lowering spring version. My rear end is brand new and torn down, I could do it.
So are mine, and that's good because of the more detail it allows. I did the drum to disc swap too. I have tons of available info, but no digital camera. (only advantix based 35mm) But I can still do it. I have most of the spring text done, and I'll pm/mail it to you when I get it done.
Since you can HTML it, why don't we scan the haynes manual pages for a brake FAQ? I see tons of questions in here that could be answered by linking them to the scanned pages. Even better if they were in PDF format.
(sorry to off-topic this thread, it's for the greater good)
I dont have the manual right now, but if you scan it in and email it to me.
