help?!!! no brakes
Old Dec 28, 2004 | 04:02 PM
jz3082's Avatar
help?!!! no brakes
I did the ls1 brake upgrade on my 94 and that was pretty simple but for some reason the brakes won't bleed correctly. No matter how many times i bleed them and the hydraulic modulator they are still squishy and barely work. Anyone have any ideas. THanks.
-Jeff
Old Dec 28, 2004 | 08:22 PM
camaroz28_97's Avatar
Re: help?!!! no brakes
how did you blead them?? their is probably still air in the line.
Old Dec 28, 2004 | 08:51 PM
94blackz14.2's Avatar
Did you put the calipers on the correct sides. My friend and I ran into the same problem on another veichle and it ended up that we had them on the wrong sides causing the bleeder to be on the bottom side of the caliper instead of the top. We bleed and bleed till we couldn't blead anymore and then figured out our mistake. Just something to look for.
Old Dec 28, 2004 | 11:35 PM
jz3082's Avatar
they are on the correct sides and i bleed the modulator then the rear and fronts in order and still air in there. How would i get it out?
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
