Help!! Brakes barely working.
Old Apr 2, 2007 | 04:34 PM
ChevyTuffD.A.'s Avatar
Ive had a problem with my brakes for a while but I never realized how bad it was. They dont stop the care very well at all. I went to pull into my parking space and was doing like 3mph and I hit the brakes to stop and it goes all the way to floor and the car comes to a slow stop. I have tried to bleed the brakes but it doesnt seem to help. Any ideas??
Old Apr 8, 2007 | 08:57 PM
Severous01's Avatar
you got ABS? you have to hit up a dealer to bleed that one.
Old Apr 8, 2007 | 09:11 PM
So if you have ABS, theres something differant you have to bleed?? I wasnt aware of that. Whats the deal with it? Can you explain a little more?
Old Apr 9, 2007 | 08:22 PM
Severous01's Avatar
yeah...you have to plug the "GM ONLY SCAN TOOL" to the data port, do what it says.
it's crazy...like 25 steps. hook it up and it'll give the vin, you verify, ask for the 8th vin #, ask for 10th number, ask for 2d number...then you'll bleed the rear, it'll bleed the abs, you bleed the driver's rear, it'll bleed the abs, you bleed the abs, it'll bleed the abs, you bleed the front pass, it'll bleed the abs, you bleed the driver's front, it'll bleed the abs.
then, after all that, you bleed the abs and it'll bleed it again. then, the scan tool will check and see if everything is ok, and you may have to possibly do it again...all of it.
it may ask you to completely empty the res and refill with fresh fluid...which you should do any way...but then you'll have to start from step one...crazy.
Old Apr 9, 2007 | 08:31 PM
Dang, sounds like a bunch of bull ****. Any idea about what it costs at a dealer?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Boss002
Jan 20, 2016 12:17 PM
whitehooptie
Jul 12, 2015 06:10 PM
Fastbird93
Jul 11, 2015 04:37 PM
Boss002
Jul 9, 2015 03:33 PM
