Got a small question?
Old Jan 3, 2005 | 07:49 PM
Camaro350z28's Avatar
I'm curious.. would it be ok to install subframe connectors before i put in my new kmember? i have a damage one and am replacing it with a stock one but am having a hard time picking one up.
I want to install subframes i have i just dont know if i should wait til the kmember is fixed and if i would run into any problems? thanks
Old Jan 3, 2005 | 08:11 PM
OBE1 95Z28's Avatar
Re: Got a small question?
Subframe connectors and the K member don't directly tie to each other so you should be fine installing them in either order. Do you suspect that the impact that damaged your K member "tweaked" your front sub frame?
Old Jan 3, 2005 | 08:30 PM
From what it appears i believe its just the kmember and control arms. So installing subframes sounds like its a go then. Thats good news. I'll be sure to check into in awhile installing and if i have any troubles then i can imagine maybe the subframe is tweaked.
Is hotchkis a decent subframe connectors? What is a good choice.
Brake_L8
Jan 20, 2015 09:44 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Sandersen511
Jan 13, 2015 03:49 PM
Lederman1976
Nov 30, 2014 05:21 AM
siguy
Nov 27, 2014 10:07 AM
