front in of car has bad wobble when backing up in either direction
What up guys
When I back up.......left or right my front end wobbles pretty bad like something is bent. My axle seems fine because it drives fine when going forward. Could this be steering, rack and pinion, front wheel bearings???? Need some help.
Re: front in of car has bad wobble when backing up in either direction
Jack the car up and look the suspension components for issues (bad ball joints, excessive wheel bearing play) or take it to an alignment shop; they can diagnose the issue. Then you can decide if you're going to fix it or have them do the repair. I can't think of anything that would only cause it to "wobble" in reverse and not while driving forward.
ChrisFrez
Dec 15, 2014 03:09 PM
NewsBot
Dec 3, 2014 12:30 PM
Jul 4, 2005 05:00 PM
