Eradispeed rotors W/ EBC green pads squealing :(
Old May 23, 2004 | 01:21 PM
ZIPPERR's Avatar
Arrow Eradispeed rotors W/ EBC green pads squealing :(
I just had this package installed 2 weeks ago. A couple days after install they stared to squeak alot, and has been ever since. I have been easy on them the whole time. Anyone know what may be causing this? I even made sure they were sparyed with brake cleaner to remove any oil on rotors after they were installed.
HElp!
Old May 23, 2004 | 04:05 PM
6speedZ28's Avatar
Thats what happens when you go with cheap rotors
Old May 23, 2004 | 06:36 PM
ZIPPERR's Avatar
After 750 bucks they better not be cheap. I think I will contact tbryne to see what they will do.
Anyone else have any suggestions?
Old May 23, 2004 | 07:11 PM
VegasZ's Avatar
Try the VGX pads. They claim that they dont squeak and they dont. Ive had them on my vert for three years after having enough of the squeaky GM pads. I am running powerslot rotors and have never heard a peep.
Old May 23, 2004 | 08:08 PM
Bud M's Avatar
I'm running Greenstuffs and Eradispeed rotors on the rear. No squeaks. So its not that is a bad combination. You might try putting something on the pads where they contact the caliper. I use a product called Pastelube. Its a synthetic hi temp lubricant, sort of like grease. That might end the squeak.
Old May 23, 2004 | 08:28 PM
ZIPPERR's Avatar
I am running them all the way around, The thing is I don't really know if the noise is coming from the front, back or both. I didn't put any of lube stuff on, Maybe that was my mistake. Wouldn't that lube look ugly though the wheels? I may have no choice tho.
thanks for the repiles
Old May 23, 2004 | 08:37 PM
alteregoss2000's Avatar
I have powerstop cross-drilled and slotted rotors and ebc red stuff brake pads. The pads are supposed to be low dust pads, but there just different color dust, its like a yellow color. Between the pads and the rotors sometimes when I stop it sounds like a school bus stopping, they kinda hum/vibrate. But all and all they whole setup stops on a dime and cost approx $700 dollars. If I had to do it over I would'nt spend that much on pads.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
NewsBot
Sep 30, 2015 04:20 PM
scottcba1
Sep 8, 2015 09:52 AM
