E-brake light staying on...
Old Jul 18, 2005 | 03:29 PM
MTL_Z28's Avatar
The other day I was having some fun in the parking lot, and used my line lock kit to do a huge burnout (don't usually pull these stunts, but I was with some buddies ) And then I noticed that the rest of the day my e-brake light stayed on. By searching I found that the the e-brake light actually stays on when it senses difference in pressure in the breaking circuits, so that would explain it, but the light has remained on for a few days now. I even tried disconnecting and reconnecting my battery and it still stays lit up. Could I have a problem?
I used my line lock at the track a few weeks before and didn't have this problem.
Old Jul 18, 2005 | 05:38 PM
Kataklysm's Avatar
Re: E-brake light staying on...
Try bleeding the brakes or the ABS unit itself. My light was on for months until I bled the ABS unit.
Old Jul 18, 2005 | 06:45 PM
Z28Nut's Avatar
The switch that triggers the brake warning light doesn't always reset or center after it gets tripped by a pressure differential so go back to the parking lot and try some really hard braking from speed. That'll usually be enough to reset it.
Old Jul 21, 2005 | 06:13 PM
MTL_Z28's Avatar
Thanks for the replies, I ended up bleeding the front brakes and it took care of it thanks alot.
Magenta_Hearts
Mar 29, 2017 08:54 PM
mattstrike
Mar 11, 2015 07:33 PM
eazyZ
Mar 1, 2015 07:12 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
squarehead
Jan 15, 2015 07:02 PM
