drums to discs on 10 bolt rear
Old Aug 8, 2006 | 08:44 PM
Camaro_Boy's Avatar
http://www.angelfire.com/hiphop/doug...isc_brakes.jpg
these are the disc brakes i want. i got a 10 bolt rear. its currently drums. i havent ever converted to disc however. from what you see there is that everything you need? i thought i would need a mount to hold the rotors? am i wrong? or does is the hub the same from the rear drums? does the brake booster and master cylinder not need to be changed out? i always thought you had to?
thanks so much for all the help
Douglas
Old Aug 9, 2006 | 05:10 AM
PoorMan's Avatar
Re: drums to discs on 10 bolt rear
Link not working. Anyway, it maybe cheaper to buy a 10 bolt with brakes already on it. For a 4th gen I know they go for like $200 used. They are pretty weak and nobody seems to want them. With an M6 and Slicks they go Boom!
Old Aug 9, 2006 | 06:44 AM
Camaro_Boy's Avatar
yeah but if it goes "boomb" you cna change out the gears in the rearend for stronger gears no? im not to knowledgeable in the camaro reend. thanks for the fast reply
Douglas
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
grabbem88
Feb 17, 2015 07:49 AM
ddr698
Jan 9, 2015 10:05 AM
Cam's maro
Jan 8, 2015 05:01 AM
