does an LS1 steering linkage fit an LT1?
Old Jun 3, 2006 | 05:00 PM
JoeliusZ28's Avatar
it seems i destroyed my linkage putting it back in after a header install. It wouldnt go on, so i had to use force and that didnt go so well I have about 2" of play in the wheel now. Anyway, i got a line on an LS1 linkage and im wondering if itll fit.
edit: I have pacesetter LTs if that makes a difference.
Old Jun 3, 2006 | 09:53 PM
wrd1972's Avatar
Re: does an LS1 steering linkage fit an LT1?
Yes it will fit, but it will cause the steering wheel to be very off of center which will only be annoying. You will need an alignment to center up the wheel.
Old Jun 3, 2006 | 10:11 PM
1racerdude's Avatar
I put the shaft from the steering shaft to the rack and pinion from an LS1 and it worked. Ya will have to align the front end to center the steering wheel(maybe). It gets rid of the rag joint and a hell of a lot more clearance.
There is no center spot in a rack and pinion like in a sector of old.
Old Jun 3, 2006 | 10:19 PM
wrd1972's Avatar
Getting rid of the rag joint is a plus. You will need to align.
I am going to do a rag joint eliminator on my current shaft sometime soon.
Old Jun 3, 2006 | 10:24 PM
1racerdude's Avatar
That still doesn't get rid of the big flanges that bolt to the cloth.
Old Jun 4, 2006 | 08:22 AM
wrd1972's Avatar
What is the issue with the big flanges?
If its clearance then that is not a concern to me. My headers don't come close to these flanges.
Old Jun 4, 2006 | 05:34 PM
JoeliusZ28's Avatar
thanks for the info guys
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
ro2207
Dec 4, 2014 06:18 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
Jul 4, 2005 05:00 PM
