View Poll Results: which is better, disc/drum or disc/disc?
disc/drum
0%
disc/disc
100.00%
they both perform the same because the disc/disc uses a stronger booster
0%
Voters: 3. You may not vote on this poll
disc/drum vs disc/disc non racing
Old Feb 14, 2006 | 01:17 AM
damien8618's Avatar
Which is better disc/drum or disc/disc or do they perform the same because the disc/disc setup uses a stronger booster? Rember this is non racing only, so its not whether one is better for heat because obviously disc brakes have less brake fade(overheating).
Old Feb 15, 2006 | 03:30 PM
RE AND CHERYL's Avatar
Re: disc/drum vs disc/disc non racing
Sorry, but thats a dumb question. Although drum brakes have a larger contact friction area, they are in a state of mild overheating almost as soon as you apply the brakes. In my old 69 the drum brakes worked great from 30mph. But if you were to hit the brakes at 100MPH and lett off them at 50mph, then reapply them. You'd have NO brakes when you tried the second time.
There is no difference in the booster used on a drum brake vehicle. In fact...drum brakes require less brake pressure to work then disc brakes do.
The time of the drum brake has passed. I doubt you'll see a car manufactured with them in 10 years.
Re'
RUENUF
Mar 13, 2016 03:37 PM
Daluchman1974
Sep 11, 2015 06:12 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
