Decarbon shocks: 1LE and regular?
Old May 28, 2004 | 04:49 PM
96LT1Fan's Avatar
Is there a difference between the Decarbon gas shocks that GM put on the 1LE cars in 93 & 94 and the Decarbons that came stock on later years (after they started putting Koni's on the 1LE cars)?
Old May 28, 2004 | 07:23 PM
OBE1 95Z28's Avatar
If you're looking to change shocks, I wouldn't look at any of the DeCarbon parts. Lowest cost upgrade is a set of Bilsteins. Search the Autocross board.
Old Jun 1, 2004 | 01:48 PM
96LT1Fan's Avatar
I wouldn't deny for a second that the Bilsteins are a superior product, but I could get the Decarbons for MUCH cheaper. Does anyone have an answer for my original question? Thanks.
Old Jun 1, 2004 | 04:04 PM
Shempy's Avatar
Good luck, with only 154 1LE's in 93 and 94, I don't think you're going to find them. Further complicating them, the Decarbons even switched midyear in 1994.
Old Jun 1, 2004 | 09:40 PM
lateapex's Avatar
Re: Decarbon shocks: 1LE and regular?
Yes, the 1LE deCarbons are different. They have stiffer valving for the 1LE springs, and the rear 1LE shock is increased to the diameter of the fronts.
I’ve been using the 1LE deCarbons for 3 years, and I like them for both street and road course. The car is much better damped than with the Z28 deCarbons. I decided to try them after GM High Tech Performance used them on their Thunderchicken project car to upgrade it for road racing. By the way, deCarbon invented and patented the high pressure single piston gas/hydraulic shock, and Bilstein builds their own version under license from deCarbon.
The appropriate shock should be determined by the spring rate it is required to damp. GM chose the valving for the shocks based on the 1LE spring rates. If you are going to run VERY stiff springs, you will need more shock than the 1LE deCarbons (or Bilstein HD). The later 1LE shocks (Koni) were fully adjustable so that they could match a fairly wide range of springs.
That said, I would not recommend that anyone buy deCarbons. They are made by the Frunch in Franse. If you do decide to buy them, be careful to get the original part #’s and verify with your dealer that the # does not cross over to a new #. Many of the 1LE parts are discontinued and if you order one, you can receive the standard F-body part instead. I have experienced that with the 1LE bushings.
Old Jun 2, 2004 | 12:26 PM
96LT1Fan's Avatar
Re: Re: Decarbon shocks: 1LE and regular?
Thank you.... exactly the kind of info I was looking for.
Formula Steve
Sep 19, 2023 08:31 AM
Kinglouui
May 26, 2016 11:05 AM
force10
Jul 30, 2015 04:56 PM
Jlo
Jul 29, 2015 03:52 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
