Crunching/creaking under moderate/heavy acceleration
Old Sep 6, 2005 | 11:23 PM
FastrDamnit!'s Avatar
Question Crunching/creaking under moderate/heavy acceleration
car in sig.
During moderate/hard acceleration OR with any type of load on the car like extra passengers or steep hills I get a loud crunching/creaking sound coming from the center tunnel under the shifter. The tranny shifts fine and does not slip so I'm guessing its external.
We replaced the stock tranny mount about 10k miles ago with an ES poly mount and when the car is jacked up there is no movement from the tranny/driveshaft and the mount bolts are tight.
Might this still be the tranny mount? or something with the torque arm??
Any input would be appreciated.
Old Sep 8, 2005 | 01:31 PM
Black_95Formula's Avatar
Re: Crunching/creaking under moderate/heavy acceleration
Sounds like what I had... turned out to be the rear. If it gets progressively worse then I would take a look at the gears. It always sounds like it's coming from the shifter area. Good luck.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
greenzee28
Sep 25, 2015 04:29 PM
CARiD
Sep 7, 2015 08:21 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
