Cover for a 9 bolt rear??
Re: Cover for a 9 bolt rear??
If you mean a 9 inch ford rear axle.. they have no rear cover, but there is already a drain and fill hole on the housing. If you mean a 10 bolt chevy rear axle, SLP makes a 10 bolt cover that is stock but has a drain plug welded on it. The fill on a 10 bolt axle is on the passenger side front part, there is a pipe plug in the housing.
Originally Posted by blue69camaro383
look on thirdgen.org in the aftermarket section...there is one that should be for sale by spring
Dec 4, 2014 11:56 AM
