Corvette calipers
Old Jun 4, 2004 | 09:43 AM
Pig Pen's Avatar
Corvette calipers
Will the red Z06 calipers bolt on and work with the stock size rotor on a '94. I can't really afford to do the whole conversion right now but I am going to do brakes soon and I want something that looks a little better. I was thinking of buying a set of used calipers and having them powder coated but if the corvette calipers will work I think that would be easier.
Thanks for the help
Old Jun 4, 2004 | 09:50 AM
GREGG 97Z's Avatar
No, Z06 calipers will not work with our stock rotors. Z06 calipers are fairly cheap but the whole conversion required to run them gets pretty expensive, around $800 I believe.
You need Z06 calipers, Z06 rotors and a special adapter braket to be able to mount those calipers to your spindles. I think you may even need LS1 spindles. I looked into it, it gets pricey.
I think I'll stick to an LS1 brake upgrade with aftermarket rotors when I do mine.
Old Jun 4, 2004 | 11:53 AM
1BadBrd's Avatar
You will be happy with LS1 brakes and aftermarket rotors. I was
Old Jun 4, 2004 | 01:52 PM
LT4Firehawk's Avatar
Get the LS1 upgre, it's more than enough for most uses (even roadcourse use w/ race pads). I did the LS1 upgrade earlier this year, and am very happy with it. Braking on track w/ Carbotech XPs stops better than my Z06 did. If you decide you need even more braking power, you can get the adaptors from LGMotorsports to allow C5 rotor use for $250. I'll proabably do this, but just so I can have a little extra mass for repeated brake use on track.
G-BODYT56
Jan 14, 2022 11:14 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
Henson071
Sep 18, 2015 04:01 PM
rvonsternberg
Sep 14, 2015 11:58 AM
