Correct front rotor size replacement for '99 WS6?
Old 05-15-2012, 09:11 PM
2QUIK6's Avatar
Seems there are several different size rotors listed as fitting a '99 TA WS6 suspension, actually the WS6 isn't an option so I'm assuming all V8 cars and maybe even V6s had the same size front rotors??
Major difference in thickness, one is 1.024" and the other is 1.272". Diameters of 11.93" and 12.008" which isn't that much difference. Which is correct??
2QUIK6 is offline
Old 05-21-2012, 12:45 PM
2QUIK6's Avatar
Re: Correct front rotor size replacement for '99 WS6?
Took wheel off and mic'd the rotors, they are 1.257 thick so the thicker ones are the ones to use.
2QUIK6 is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
Jazsun
12-29-2014 12:14 PM
Hurin
12-13-2014 07:38 PM
Quick Reply: Correct front rotor size replacement for '99 WS6?
