clunk in rear
Old Sep 25, 2006 | 07:06 PM
CLEAR's Avatar
clunk in rear
over the smallest of bumps im getting somewhat of a popping clunk in the rear of the car, possibly driver side. things seem to look ok. anyone else have this and what fixed it?
Old Sep 25, 2006 | 07:25 PM
2001NBMZ28's Avatar
Re: clunk in rear
LCAs torqued correctly?
Old Sep 25, 2006 | 07:29 PM
01Z's Avatar
01Z
Re: clunk in rear
All 3 of the 4th gen camaros I have had make / made a light popping over slight bumps in the road. Bigger bumps did not give me the same noise. I could not be sure if the noise was front or rear. When I lowered my 2001 and replaced the front struts within the springs the noise went away completely. If you are positive the sound is from the rear then it won't be what i have had but it still could be those orange shocks if you still have factory.
Old Sep 25, 2006 | 07:37 PM
CLEAR's Avatar
Re: clunk in rear
yea its from the rear for sure. i kept thinking the exhaust was moving or something with the filler neck but its not either of those. im leaning toward the shock.
Old Sep 25, 2006 | 08:40 PM
CLEAR's Avatar
Re: clunk in rear
it definately makes the noise when the back of the car raises up like when braking.
Old Sep 25, 2006 | 09:41 PM
01Z's Avatar
01Z
Re: clunk in rear
If you find it isn't the shocks then I guess I would take a good look at the sway bar links, bolts and supports as well as the control arm bushings. Check the fasteners and moving points on the panhard too. If you're not positive it is actually the suspension then test your u-joints, axle and transmission mount when you have the car up on stands.
Old Sep 25, 2006 | 09:56 PM
Severous01's Avatar
Re: clunk in rear
check the exhaust where it passes over the "tunnel brace". mine was hitting there after a catback install. also, right over the axle it hit the chassis too. some slight bending of mounting brackets fixed it.
HarleyZ28
Oct 5, 2015 06:23 AM
warmeck
Mar 22, 2015 06:43 PM
Fatdog2
Feb 12, 2015 12:24 PM
ModdedNerd
Dec 18, 2014 10:52 PM
