Can't get new pads to fit over rotor...
I compressed the piston back in with the c-clamp, but the pads still aren't making enough room to get over the rotor. What am I doing wrong?
Re: Can't get new pads to fit over rotor...
you sure the piston fully seated and the pads are seated properly?if so id try a new set of pads cause theres no reason it wont fit.also befor eyou hit the caliper with the c clamp i hope you pinched of the line and cracked the bleeder?the old days of squeezing piston dont cut it with abs since you push a lot of sediment back into the lines and accumilator..fyi
carguyshu
Jan 22, 2017 11:19 AM
stockssn2o
May 25, 2015 08:54 AM
May 1, 2015 01:14 PM
