Camber Kit
Old Feb 9, 2010 | 11:24 PM
camarolover97's Avatar
Camber Kit
Does anyone know if camber kits are made for LT1's
any websites...
Thanks,George
Old Feb 10, 2010 | 05:21 AM
Camber kits are for "strut" style suspensions (e.g. 3rd Gen F-Body, Mustangs). The 4th Gen F-Body has an unequal upper/lower A-arm suspension, with a coil over shock. The camber is adjusted with the two bolts that hold the lower A-arm to the K-member. In most cases, you can achieve decent camber settings with that adjustment.
In an extreme case, where you can't get the setting you want, you would get adjustable tubular A-arms.
Old Feb 10, 2010 | 11:20 PM
thank you very much
lt1xondeck
Mar 18, 2016 07:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
