C5 Front brake Conversion LT1... hard or not?
How hard is it to do a C5 front brake swap on an LT1? and what is its advantages and disadvantages? and how much would it cost me roughly?
I didnt think it was too bad but i had the car on a hoist and air tools as well. The only thing that i didnt like was cutting the spindle. This was one of the best mods thati did however, the car stops unbelievably better than it did stock especially repeatedly where there is no noticeable fade. As far as cost it depends on weather you bu new or used but i would say it was worth while. Also i did ss lines at the same time.
so other then cutting the spindles... its anormal brake job bascly??.... and how much are they brand new?? and can u get them in Blue?
also... would prostars skinnies 15x3.5in still fit with the usual spacer on the front with the C5 brakes???
No blue, just red or gray calipers. If you want blue you'll have to paint them yourself.
You remove the stock discs, calipers and brake lines, cut the spindles, install the caliper mounts, install the new brake lines, calipers and discs and bleed the brakes. Pretty straightforward.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Brake_L8
Jan 20, 2015 09:44 AM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
