C4 brakes?
Old Dec 8, 2007 | 08:32 AM
wildweasel's Avatar
C4 brakes?
Here is a whole series of dumb questions. Are C4 calipers two piston? Are C4 rotors the same size as on an LT1 camaro? I guess what I'm getting at is would C4 brakes bolt onto my camaro w/o a spindle swap or some adapter plate or anything like that. Should I just forget it and go with the LS1 brake conversion?
Old Dec 8, 2007 | 08:50 AM
PoorMan's Avatar
Many do the LS1(Z28) 12" or the C5(Z06) 13" upgrade that requires 17"+ wheels. AFIAK both require spindle modification and/or a caliper adapter. I never seen anything on C4 brakes on a 4th gen.
Old Dec 21, 2007 | 10:02 PM
OBE1 95Z28's Avatar
The Baer Track Kit is the C4 setup. The front calipers are 2 piston and the Baer Kit comes with 13" rotors. The kit comes with a caliper mounting bracket that requires a portion of the steering knuckle to be cut off.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
