bushings
bushings
I am ordering some polyurethene bushings for my 94 LT1
What is the sizes of the stock sway bars (32mm?) and rear(19mm).
what brand do you all recommend, and I am installing a bmr k member, what poly mounts should I get, a-arms up and lower, ball joints (stock?).
also, trans mount etc etc.
thanks mark.
thanks mark.
Re: bushings
Stock Sway bar sizes are Front:30mm Rear:19mm. I am doing the same research for my 94 LT1 also..Im looking at these from thunder racing cause they are on sale and very cheap...Make sure you order the endlink kits for front and rear also cause they will also be worn out.
Check this link Im gonna order these now actually.
http://www.thunderracing.com/catalog...&vid=4&pcid=92
As far as other things you are asking,im not really sure what you are asking
sleeperZ96BT
Sep 9, 2015 08:28 AM
Apr 16, 2015 09:57 AM
