brembo vs. wilwood vs. baer eradispeed
Old Dec 3, 2004 | 04:15 PM
DiabloGT's Avatar
out of brembo, wilwood, and baer eradispeed, which brakes are the best and rank them from 1-3 1 being best.
thank you
Old Dec 3, 2004 | 04:49 PM
mitchntx's Avatar
Re: brembo vs. wilwood vs. baer eradispeed
1) Brembo - proven across multiple platforms and parts are very easy to obtain. Lots of race shops are Brembo dealers. I have 4 piston Brembos on my car and they freaking stop ...
2) StopTech - basically a Brembo clone. The German car owners really like them. Lou Gigliotti runs them on his World Challenge C5.
3) Wilwood - Seems to work very well on my nephew's Firehawk. It does seem to be a little tougher to get pads and rotors, though. Very limited distribution network. You should probably seek price and availability before you order.
4) Eradispeed - driveway jewelry
MHO - YRMV
Old Dec 3, 2004 | 05:38 PM
Camaro_Maniac63's Avatar
MHO - YRMV
^^ What he said.
Old Dec 3, 2004 | 06:51 PM
DiabloGT's Avatar
MHO - YRMV
yeah, im thinking of brembo but its too expensive its 2.9k, do you know any place that sells em cheaper?
Old Dec 3, 2004 | 07:29 PM
Severous01's Avatar
you can rip a set off the new infinitys. they come stock on the higher end cars. the new 350z clone has them stock. you'll need to fab the spindle or make a bracket like bob's c5 brackets. also youll need some new wheels if you dont already have a shallow 17 or 18's. my friend just recently bought some wilwoods, they are a pain to put together, you have to loc-tite everything, also he had to wire every nut to another so they dont back off. took him about 4 days. a lot of this stuff needs to be looked into before you purchase "big brakes". i'm not sure, but i think the brembo's come assembled, well, as assembled as possible. the rotor hats are connected to the rotor blanks.
Old Dec 4, 2004 | 04:12 AM
mitchntx's Avatar
It's a tough check to write and I thought he exact same thing ... till I got them on the car and saw what kind of maintenance they required.
Almost 2 years of road course/daily driving duty on 1 set of rotors and pads ...
Old Dec 4, 2004 | 03:14 PM
DiabloGT's Avatar
from a 1 to 10 how good do they slow down?
oh and the idea of the ones from the infinities, i think ill just stay to getting new ones from a discount place somehow instead, beacause i dont want to go with to many problems of fitment issues etc. do you know of any place that probably is a couple hundred less than 2.9k!?
Old Dec 4, 2004 | 06:26 PM
Are you actually going to road-race this car, or are you just looking for the best brake setup for the street? If you won't go racing, Brembos might be overkill for you. Also, like Mitch said before, you can get the Stoptechs which are very similar to the Brembos for around $2k. Good luck.
Old Dec 4, 2004 | 08:34 PM
mitchntx's Avatar
Any of those packages will slow down hard enough to hop the rear axle, with the proper pad compound. Even the stock brake package will do that ...
It's the cost of replacement parts and the frequency of replacement is the key point ...
Old Dec 5, 2004 | 01:45 PM
DiabloGT's Avatar
i always road race
o and how about a brake conversion for my 95' z28 from a 02' z28 or c5 vette/z06 do the z06 brakes fit on my 95'?
Old Dec 5, 2004 | 08:14 PM
DiabloGT's Avatar
will these fit on a 95' camaro even though its for 98+?
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
where can i get the right calipers for them?
Old Dec 5, 2004 | 09:23 PM
Black_Z28's Avatar
No, those will not fit on a 95. The 98+ cars have a larger rotor, plus two piston calipers. So, if you wanted to put those on you'd need to do what's commonly known as the LS1 brake swap.
Old Dec 5, 2004 | 09:29 PM
DiabloGT's Avatar
yeah i heard about them, do you have any links for it? what parts do i need, and where can i buy them?
Old Dec 7, 2004 | 12:03 PM
Black_Z28's Avatar
Yep, just go to the following links.
Link 1
Link 2
Those two links should list all the parts that are needed.
Old Dec 7, 2004 | 01:35 PM
DiabloGT's Avatar
thanks, if i bought those brembo rotors only though for the ls1, do i still use the ls1 calipers or do i need the brembo calipers?
