Brakes
Old Jul 26, 2005 | 11:32 AM
SpeedDemon02SS's Avatar
Brakes
When i spin the wheels by hand (car lifted) i can hear the pads touching the rotors. time for new pads? or is it more serious than that?
Old Jul 26, 2005 | 12:08 PM
PAGregSS's Avatar
Re: Brakes
Front or rear?
Old Jul 26, 2005 | 12:52 PM
Greed4Speed's Avatar
Re: Brakes
its normal
Old Jul 26, 2005 | 01:04 PM
Re: Brakes
front...
gotta love the camaro breaks!
its ok though...gonna go with some baer eradi speed rotors, and get some new pads.
anyone have any suggetsion on good pads...little noise/dust/heat...good stopping power? semi-metallica?
Old Jul 26, 2005 | 01:31 PM
Bayer-Z28's Avatar
Re: Brakes
Metalica rules, but I wasn't aware that they made a line of performance friction products...
Some contact noise is normal, but what you may be refering to is related to the caliper slides. The caliper bolt bolts into the silde itself. I believe... Slide it out and clean the walls of the inside of where the bushing goes... Re lube and install. A Really SMALL cyl. hone tool works great for it..
Hawk Pads are good, but the brakes itself on my car are not really that great.. I think I still have air in the lines.. I bought rotors for my Cavalier, when I had it, and it was the best $$$ I've ever spent as far as brakes..
Old Jul 26, 2005 | 01:38 PM
Re: Brakes
haha...i ment metallic...but f yea, metallica rules!
btw...beyer...i sent you a pm.
Old Jul 26, 2005 | 02:04 PM
ChicagoTransAm's Avatar
Re: Brakes
The softer the material, the better stopping...but then more dust usually. For good bang for the buck pads, check out Performance Friction. Cheap, and they'll knock out your front teeth when stopping
Old Jul 26, 2005 | 02:06 PM
Re: Brakes
I heard its not good to change rotors and pads at the same time cause you have to bed the rotors and pads. fact/myth?
Old Jul 26, 2005 | 07:52 PM
Re: Brakes
You just don't want to switch pads on the same rotors.
Check out the C5 conversions before you dump so much cash into Baer.
Old Jul 26, 2005 | 10:28 PM
Re: Brakes
i am not changing calipers...only rotors...correct me if i am wrong...but i thougth the c5 conversion were bigger rotors and calipers?
Old Jul 27, 2005 | 07:51 PM
Re: Brakes
You can use the stock calipers, but you'll be able to run the 13" C5 rotors. I've seen some very nice C5 rotors for much less than Baers.
You'll have cooler brake, more friction surface, better stopping power, the ability to easily upgrade your brakes further, very good choices of less expensive vented rotors all for little more and possibly less $ (if you shop around).
The brackets w/G-stop rotors can be had for $530. Eradispeed front rotors alone cost ~$500 for the stock diameter.
Later if you want to upgrade calipers, they're IIRC around $89/ea for Z06 at SDPC.
Old Jul 27, 2005 | 08:55 PM
Severous01's Avatar
Re: Brakes
yeah, LG sells a bracket for LS1 cars only that will allow you to either use ls1 calipers and C5 rotors, or a full on C5 kit. it's in a weird location though, it looks kinda goofy. i like bob's style bracket better, they just look better. but if you want to go the extreme cheap route, check out lg's webpage, under ls1 camaro/ta, brakes, and check out the bracket.
the rub is normal...from what i heard from an engineer is they are made that way to "warm the pad". whatever that means...i just think it's tolerances in the caliper/rotor, or there not being any. but everyone i know has it, and it's not a problem
Old Jul 28, 2005 | 08:09 AM
Re: Brakes
are the C5 rotors cross drilled?
Old Jul 28, 2005 | 11:45 AM
Re: Brakes
The ones in the LG kit are. Cross drilled is all bling only. It'll do nothing for you except create stress points and reduce mass which isn't what you want to do with rotors.
Old Jul 28, 2005 | 11:52 AM
Re: Brakes
i know...but i like the way they look...
