brake system replacement help.
Old Feb 15, 2005 | 06:46 PM
licerio's Avatar
I am in need of replacing all my brake components (complete). Can someone tell me where is the best site to go to get the parts and what's best to get price wise the cheaper the better. I am not really into racing, just need to replace them because they are worn out and makes my car vibrate in cruise. I think. I will be replacing rotors, calipers, pads.... and please add more or if there is any complete kits out there. Please let me know. thanks guys.
Car info:
1994 Camaro Z28
92 K miles. (original brakes)
Old Feb 26, 2005 | 10:09 AM
NJSPEEDER24
Guest
Posts: n/a
Re: brake system replacement help.
Go to an auto parts store in person. NAPA works for me.
Old Feb 26, 2005 | 11:40 AM
stereomandan's Avatar
You should only need to replace the rotors and pads, and fluid. No need to change calipers unless you want a big brake system.
Hawk HPS pads are popular for the street, but may be more than you want to spend. You can find them at www.thunderracing.com You can find rotors there too, but you could probably get away with a less expensive rotor. A plain, non slotted, non cross-drilled will work fine.
For fluid, I highly recomment ATE TYP 200 found at www.raceshopper.com
Dan
squarehead
Jan 15, 2015 07:02 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Hurin
Dec 13, 2014 07:38 PM
