Brake pads? Which ones?
Old 04-07-2004, 12:14 AM
tombodad's Avatar
Hey guys
time has SCREEEECCHHH come for me to ScREEEECCHHH change my SCREEEcCCHHH brake pads SCREEEEECCCHHH. (sorry, i know thats gay, but its late and im bored lol) So y wuestion is shich brake pads are good? theyre not all that hard to put in are they? im a fairly decent mechanic i dont hink they wouldbe, just makin sure. THanks guys (and girls
tombodad is offline
Old 04-07-2004, 08:38 AM
stew w/00&92's Avatar
I like my hawks....
stew w/00&92 is offline
Old 04-07-2004, 09:34 AM
rncotton's Avatar
I've been very pleased with my AutoZone Aimco rotors ($34 each) and Raybestos ceramic pads ($150 for 4 wheels) The ceramic pads are quiet and dustless.
rncotton is offline
Old 04-07-2004, 11:48 AM
Admin Emeritus
JasonD's Avatar
We have added a few new forums, and one is for Susppension, Chassis and Brakes.
I am moving this one there now...
JasonD is offline
Old 04-07-2004, 11:49 AM
Moderator
PhantomTA's Avatar
dont confuse me now!
PhantomTA is offline
Old 04-07-2004, 11:50 AM
Admin Emeritus
JasonD's Avatar
Take aim before you put your finger on the trigger then!
JasonD is offline
Old 04-07-2004, 03:47 PM
Jerm's Avatar
Location: You know when they Quit Suckin that something is Wrong!!!!
Originally posted by stew w/00&92
I like my hawks....
Just put mine on, have yet to get some mileage on them and run thru the canyon w/ them
Jerm is offline
Old 04-07-2004, 04:43 PM
Aeromaks's Avatar
I will add a few cents before this gets moved...
I did front pads on my camaro, put on Hawk HP pads on, work well, good stopping power, and like $52 from jegs. =)
I have never doen brakes myself, nor anything else for that matter, and I was able to change them myself in about 1 to 2 hours.
If I was to do it over, I can do it in abou 45 to 1 hour.
Just make sure you have the right tools. You will need i forget, 15mm? hex wrench, get it on a socket. =) and a torque wrench, those are a must. Get plenty of brake cleen asit helps.
Hey, saves you quite a bit of money doing it by yourself.
Aeromaks is offline
Old 04-08-2004, 01:12 AM
iiiezekieliii's Avatar
i use the hawks and some 10 dollar rotors, they all seem to work fine....
iiiezekieliii is offline
Old 04-08-2004, 02:40 PM
Tang's Avatar
I bought NAPA Ceramix front and rear for my car. Unfortunatly, I was unable to afford the good rotors, so I was forced to buy the cheapies. Either way I think my pads are excellent. They stop very well, They've never squeaked, AND they leave VERY VERY little brake dust. I had some semi-metallics on before and after a week my wheels were almost black. I decided it was time to buy the ceramixs. I think it was a problem with the brake pads though, I've never had a set dust that bad. For the NAPA Ceramix's I paid somewhere around 50 for the front and 70 for the rear. I used my works discount on those so I'm not sure what they'd cost to the average walk in customer.
Tang is offline
Old 04-09-2004, 11:19 AM
Coolformula's Avatar
I got hawks all four wheels. I got powerslots on the front and cheap advance on the rear. I wouldn't spend a ton on rear rotors since front is where 70% stopping comes from on a rear wheel drive.
Coolformula is offline
Old 04-09-2004, 07:19 PM
Terran2k's Avatar
I like my EBC pads, but theyre a tad on the expensive side.
Terran2k is offline
Old 04-09-2004, 08:54 PM
Fastbird93's Avatar
I've been on EBC Greenstuff for a couple years now. I will NEVER go back. I don't get brake fade nearly as bad as stock, and all I'm using is those and Hawks Pro-Stop slotted rotors (the ebay specials). Stops a helluva lot better too.
Fastbird93 is offline
Old 04-10-2004, 03:46 AM
S.J.S.'s Avatar
got me some Hawk Pads and some Pro Stop slotted rotors off of Ebay.
S.J.S. is offline
Old 04-10-2004, 05:27 PM
darkangel95's Avatar
I just installed a set of the Hawk HPS pads on all four corners this past week and I have been impressed with them so far.
darkangel95 is offline
Quick Reply: Brake pads? Which ones?
