Body mount Torque arms?
Old May 30, 2005 | 12:42 AM
River City Speed's Avatar
I was looking at Thunder Racing's selection of TA's. That have ALOT of them. I'm intrigued by the ones that remove the mount from the transmission. Do they bolt in place of the stiffener that connects the trans tunnel sides? I removed that about three years ago when I put longtubes and a 3" Y-pipe on. What are the main benefits of that besides not breaking tail shafts on the trans?
Old May 30, 2005 | 09:36 AM
simple's Avatar
Re: Body mount Torque arms?
some, not all of the relocated tq arms mount too the tunnel brace mounts
the idea of moving the mount other then the stress issue on the trans is too change the leverage point at which the arm pushes the rear axle into the ground
search google for torque arm suspension and read up on some of the theories as too what kind of torque arms work for what applications
theres alot of different ideas about what does what for what situation
etc.
like longer torque arms are better for road racing becaue of braking and shorter, without being too short are better for drag racing because of the shorter load transfer too dig the rear axle into the ground
then there are TQ arms that have a good combo for both types of situations like the GW trac link
a decoupled torque arm (free of attachment at the front) is suppose too be best for drag racing, it is choice style among stock eliminator racers
Old May 30, 2005 | 01:14 PM
flyinZ's Avatar
Priced out the decoupled tq.arm, and it runs about $750 ,but its one of the best ones...Or something like the Madman arm', which is around $500, I think and its double adjustable..
Old May 31, 2005 | 10:55 AM
mongse_1's Avatar
I've got a Madman on my car. The crossmember mounts where the old g-load brace went. Instead of bolting it in, I welded mine in place and also welded the ends to my SFC (which are in turn, welded to the body). It's also one less thing I have to take off when I drop the drivetrain too.
Old May 31, 2005 | 11:42 AM
magnumv8's Avatar
Ive got the Sphon adjustable unit that mounts to the old crossmember location. It is a very nice piece. You can get it with built in driveshaft loops as well.
Old Jun 1, 2005 | 05:01 PM
slp223's Avatar
i went from a tranny mount to a body mount and the road vibration is much much worse.
Old Jun 3, 2005 | 03:04 PM
ABA383's Avatar
I also have a Spohn cross member mounted TA with the poly bushing and 2 loops. Its a very good piece and I don't notice any more road noise than before. The spherical rod end type will transmit more noise. Whatever TA you decide on get one that takes the mount off of the tailshaft. I learned the hard way what lots of rwtq does to an 8 year old tailshaft. Also, if your car is not lowered get front and rear loops. The rear of the driveshaft takes out lots of stuff when it lets go.....
--Alan
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
