Bmr swaybar, will i like it?
I need a new front swaybar because mine has a crack in it. I have my eyes set on a bmr one. It seems like a good price for what it is. Will i like it, will it help my turning a lot, and how does the weight compare to stock?
I am worried that it may be too stiff for my daily driver, just curious?
Re: Bmr swaybar, will i like it?
I have the solid 35mm bar and it's awesome. Yes, a hollow bar is lighter, but the improvement in handling with the Suspension Techniques 35mm solid bar more than outweighs the brawback of any added weight.
Either way, I would recommend a solid or hollow 35mm bar, especially if you have stock springs. If you have stiffer than stock front springs, then a 32mm bar might be o.k. www.stranoparts.com is a great place to start.
By the way, the big front bar does not make the car any harsher, like springs do. It simply is a great improvement.
Dan
Dan
Dave
the hollow one is significantly more expensive, will it be worth the difference?
Originally Posted by Bud M
The difference in stiffness between a solid 32 mm bar and a hollow 35 is slight. The weight difference is several pounds that you are unlikely to notice. Unless you are racing and have to have the minimum weight, the 32 solid BMR bar will be fine. It makes a tremendous handling improvement.
Sam, how much stiffer is the hollow 35 than the solid 32? How is the stiffness of a swaybar measured? I based my comments on some calculations I saw posted on FFRAX that indicated the stiffness of the two bars was similar but maybe that was not correct?
But based on your post there is a 9 or 10 lb difference between the two. I think its fair to say that the typical driver would be hard pressed to detect the extra weight.
Since bars work by twisting, the inside adds very little to it, and that become less and less as the outer diameter gets larger. If you can mark the end of a tube, and twist it you'll see the farther to the outside you go, the more movement there is.
It's been a while since I figured a 35 hollow toa 32 solid, but the difference was not a lot less than a solid 35 (which is twice as stiff as a solid 32). You give up approximately 3-5% of the stiffness of a solid bar in theory. But my bar also has less bends, as well as less acute bends than an ST bar does. So we make some of that back by having less metal to flex in the first place (which does matter,that's why shortening the arm of a bar makes it stiffer).
I don't disagree that someone would be hard pressed to tell the weight savings. I don't even think they could. But you also can't tell 10 hp, but nobody wants to give that up either. And it's a cheap way to keep weight down some if you are upgrading bars anyway.
