Blisten HD or Blisten SLP?
I've pretty much decided that the blisten HDs fit my req's and price range, but I just noticed these blisten 'SLP valved' shocks when I was about to order them........are these any good vs. the std. f-body blisten HDs?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SLE%2D70008&N=115 &autoview=sku
Priority 1 - Daily Driver(better ride in all aspects than 110k mi stockers)
Priority 2 - Firm/better handling than stock
Re: Blisten HD or Blisten SLP?
Originally Posted by Compstall
I'd go with Priority 1 unless you planned on using the car for autocrossing/road racing to gain that extra .1 second or so in lap times.
Assuming you still have stock springs, the HDs would be the better choice. The SLP shocks are designed to work with the SLP specific SS (Eibach-but not pro kit) springs.
Might be a bit firmer ride, but certainly better handling.
Originally Posted by teke184
exactly...
the slp bilsteins are revalved for a lowering spring
the HDs are for stock height
which are you?
which are you?
I don't mean to steal the thread, but would the SLP Bilsteins work alright with my BMR 1" lowering springs since they are made for the Eibach SLP springs? I think the the Eibach SLP springs lower the car an inch.
Rob
exactly...
which are you?
which are you?
this is from: http://www.tbyrne.com/lt1catalog.html
Originally Posted by Tbyrne
The SLP Bilstein shocks are built to SLP's specifications by Bilstein for use in road racing applications, yet they continue to retain excellent street manners for daily driving. The shocks are valved to produce a comfortable, yet firm ride on the street, but perform like a race shock during road course maneuvers. For the ultimate compromise in a dual-purpose shock that's not adjustable, SLP's shocks are it.
The SLP version isn't as aggressive as the standard Bilsteins and will provide you with a better ride.
What is it that you're not sure of here?
The SLP bilstein units are designed specifically for the SLP Eibach springs, which do indeed lower the car a little bit when compared to stock springs.
The bilstein HD shocks are designed for stock springs, not lowering springs.
tommalcolm
Sep 11, 2015 03:39 PM
