Bleeding ABS module
Old Jul 30, 2005 | 12:51 PM
Valkyn71's Avatar
Bleeding ABS module
Working on bleeding my brakes, and i have heard that you need to bleed the ABS first (since i let the master cylinder go dry).
The ABS unit has two bleeder valves on it, was just curious which one should be bled first? One is closer to the engine, and the other more tward the wheel.
Any input would be much apprechiated.
Old Jul 31, 2005 | 07:21 AM
MEAN LT1's Avatar
Re: Bleeding ABS module
If my memory serves correct you bleed the one on the left hand side 1st and the the one on the right.
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
1bad427ls1
Sep 23, 2015 01:12 AM
