best torque arm for using a remote mount
Old 03-31-2005, 02:56 PM
anthony714's Avatar
i need a new torque arm which doesnt rely on the stock trans mount..ive found basically 3 types,spohns,bmr,and jegs.i need to know if any are better or worse..i know they all are good companies and products,and that spohn is a nice kit with a sepreate crossmember,no welding,bmr u have to weld,and jegs you bolt onto the floor board..prices range from 250-450..so thats where ? comes in...anyone use or seen the jegs version in use?id rather spend extra cash somewhere else if i can and dont wanna have to worry about welding something
anthony714 is offline
Old 03-31-2005, 05:58 PM
Z28barnett's Avatar
Re: best torque arm for using a remote mount
This is the best TA I have seen.
Unless you are willing to go to a design like this and or you are making huge power, I would leave the TA alone.
http://www.unbalancedengineering.com/Camaro/
http://www.unbalancedengineering.com/Camaro/TA/
Z28
Z28barnett is offline
Old 03-31-2005, 06:21 PM
anthony714's Avatar
great kit and info but i got a 3rd gen,looks like they only make it for 4th gen
Old 03-31-2005, 06:22 PM
anthony714's Avatar
your also saying i should keep stock design???whats the stock one good for.i hear you can have problems with breakage.etc...im running 520-540 hp
Old 04-01-2005, 10:47 AM
mongse_1's Avatar
You could reinforce it to reduce flexing or just buy a Spohn trans-mounted unit.
Very interesting design. Took a little bit for me to figure out how it worked, but it's a pretty neat concept.
mongse_1 is offline
Old 04-01-2005, 01:42 PM
anthony714's Avatar
so stosk tas' designs ok??no real problems snapping trans?
Old 04-01-2005, 04:36 PM
speed9's Avatar
global west makes a very heavy-duty torque arm.
it eliminates the tail housing mounting point.
i run one on my 700hp 91 z28.
http://www.globalwest.net/
speed9 is offline
KYWes
05-22-2015 08:48 PM
KYWes
04-24-2015 09:17 AM
Jason Short
01-19-2015 06:34 PM
87Aerocoupe
01-10-2015 07:27 PM
Quick Reply: best torque arm for using a remote mount
