Bent Tie Rod??
Inexperienced or lazy tow truck operators could easily bend a tie rod by hooking to it to pull a vehicle. But the most obvious cause of the bent part is likely falling into the ditch in the first place. If you say the top of the tire is out (positive camber) then it's probably not a bent tie-rod but more likely a bent lower control arm.
CARiD
Sep 30, 2015 05:44 AM
