B&G or Eibach?????
Old May 31, 2005 | 06:52 PM
Black6spdZ's Avatar
B&G or Eibach?????
I am interested in the b&g springs with the 1.4" drop, i had the eibach pro kit on my 93 z28 and thought it rode a little stiff but i had sensa trac struts which i found out later that you dont want on a lowered car because of the valving. Which springs have the best ride quality because both are progressive rate springs? any input is appreciated
Old May 31, 2005 | 10:08 PM
chaser2440's Avatar
Re: B&G or Eibach?????
I have intrax 2" drop springs the ride is not to bad . The ride height looks great but some times if im not careful i can scrape the front and back end, but otherwise i love them
Old May 31, 2005 | 10:09 PM
Greed4Speed's Avatar
I have the B+G's. They are stiff. Stiffer than the Eibiotch, but also shouldn't settle like the po-kit. I'll probably step up to Konis next to handle them better, if I don't go ahead and go coil over.
I'd equate them with H&Rs or DMS front and Hypercoil rear as far as spring rate.
In all honesty, the rear seems to be a little stiff. Not horrible, but could be better.
List of spring rates:
http://www.angelfire.com/my/fastcar/suspension.html
Old May 31, 2005 | 10:43 PM
Black6spdZ's Avatar
I would like to go with the sportline kit but with the long tubes and a 3" y pipe i think they will be too low.
KYWes
Aug 10, 2015 07:03 PM
Jul 2, 2015 11:39 AM
camaro98_speed
Apr 22, 2015 11:26 AM
Dec 1, 2014 08:08 AM
