Anyone ever have issues with BOLT ON SFC'S ???
Anyone ever have any issues AFTER installing bolt of SFC's ??
I've got a set similar to the SLP BOLT ON's ...
I keep gettin these horrific binding noises or flex noises after a rear shock/spring and LCA install and we lifted the car off the subframe's that are only bolted in, I'm thinkin we might have bent something a little and now its making a lot of weird noise or that its still my first guess and its the LCA's...
What does a bad shock sound like? Do you think it possible I got bad NEW OLD STOCK shocks ???
Also on the shocks is 1 rear supposeed to be stiffer then the other ??
or do they just take a lil bit to break in?
Thanks in advance for your help, I have another post with the shocks/spring install with other details if you care to try and help me out..
YEA SAME HERE!!!! DRIVER SIDE REAR TIRE have some creaking sounds!!! wow thats odd, is this something we should look into? it does get annoying sometimes when my radio isnt cranked up
could it be something with the LCA, cause i just put some SLP take off's on the rear
