Am I stupid for thinking of this?
Old Feb 1, 2007 | 10:08 PM
danhr's Avatar
Ok I got rid of my ABS awhile ago because of my 9". Since then, I've been fighting brake fluid leaks on the hard line that goes from the prop. valve to the rear brakes. I am getting fed up with it, and am thinking about running a stainless braided line from the prop. valve all the way back to the y-block at the rear. It would get rid of the leaks, and actually should improve my braking?
smart idea or dumb idea?
Old Feb 1, 2007 | 10:29 PM
DelSoto's Avatar
don't see how it would improve things to replace a hard line with any type of flexible line steel braided or not. but if it fixes your leaks I guess go for it. why don't you fix the hard line with a hard line to fix the leak?
Old Feb 1, 2007 | 10:43 PM
danhr's Avatar
because it's hard to flare the line because it is right up against the body and in an akward spot..... I've tried reflaring it a couple of times already and if I go any further, I will have taken off so much off the line that I would end up replacing it.
my flaring skills suck.
Old Feb 2, 2007 | 01:51 AM
hotpart's Avatar
Former Vendor
Teflon flex hose is considered a maintenance item and will expand very slightly. I would recommend running a new hard line or pulling it far enough from the body to re-flare and just put an adapter to extend it.
Old Feb 2, 2007 | 06:34 AM
teke184's Avatar
exactly...go to the store and buy a 4' section of tubing with the flare nuts...then you'll have all the room you need to work
Magenta_Hearts
Mar 5, 2015 07:01 AM
kandied91z
Mar 3, 2015 11:34 AM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
