Air shocks good or bad?
Before i put a set on my lt1 ta, I want to know if they are good to put on it or should i run with a set of standard shocks. Im trying to help get rid of some of the weight transfer. Any help would be nice.
Get rid of weight transfer????? I have had air shocks on several vehicles. What I have found is they are extremely harsh and will bounce on courderoy pavement. If that is the effect you are looking for then go right ahead.
I would normally suggest adjustable shocks for both the front and rear so you can balance them for your driving situation.
One cool thing about air shocks is I had a small air pump and a switch located on the dash so i could raise or lower the back end as desired without leaving my seat.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Jan 13, 2015 09:19 PM
