Air Ride CoolRide suspension on a 3rd Gen?
Old Mar 22, 2006 | 04:03 PM
91 Camaro RS's Avatar
I've been thinking about saving up for this suspenson setup since for starters I can get it for about $650 (front and rear) and it'd be nice to get my car to handle better than it already does. To anyone else who has this setup on their 3rd gen, how do you like it and how much did it improve the handling? Does it lower the car any from the stock position and if so, how much? How long would it take to install the entire setup in my driveway?
Old Jan 5, 2007 | 12:38 AM
kandied91z's Avatar
searching probably would have helped you with this.
their typical thirdgen setup should run you around 1500-2k in parts alone. you can save money elsewhere by going with analog gauges and cheaper valves but i wouldn't recommend it.
the kit works great and is well worth the money. i'm running a custom system build by ART that i took the car too them for. the front air struts (similar to a coilover) were $1,200 for the pair alone. very similar in design to the 4thgen shockwave setup.
the rears use the coolride identical to the 4thgen rear setup. while this is an old thread if you haven't done it yet you should as it's a great modification.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
