Adusting front driver wheel?
Old Dec 13, 2008 | 09:10 PM
Gtpguy's Avatar
On my car, the front driver wheel turns out when the other is straight. What can I adjust to straighten it out? The steering wheel has to be turned a bit to the right to compensate in order to drive straight. I've taken it to a couple shops and they all say my rear end is crooked and that's what is causing the steering, but you clearly see the front driver wheel turns out when the other is straight.
Old Dec 13, 2008 | 09:50 PM
If it "turns out" in the left or right direction, the tie rod ends need to be adjusted (or you have something bent).
Old Dec 15, 2008 | 08:40 AM
redneckgames's Avatar
exactly
and go to a different shop
Old Dec 16, 2008 | 04:51 PM
Gtpguy's Avatar
Well I got under neath silver bastard today and I adjusted it. I turned twice rotated the tie rod inwards and it seemed to help it drive straight. Of course it's raining now so a true test won't happen. But visually, the tire doesn't stick out further than the other. I want to use yard sticks and place them against the outside of each tire and measure the distances between the ends. Then I can truly see if they tires are straight.
Old Dec 16, 2008 | 05:13 PM
LSWHO's Avatar
Laser pointers work too.
Old Dec 16, 2008 | 10:54 PM
If you want it right on, you need to have a shop do it. Home tools will put in the ballpark.
Old Dec 21, 2008 | 07:54 PM
blown94's Avatar
a piece of string across the tires from back to front will put you close, assuming your rear end is centered under the car, which it might not be if you have it lowered.
Old Dec 23, 2008 | 05:44 PM
JohnD's Avatar
I used a steel tape with a thumbtack through the 1" mark. Spun each tire and used a fine point marker to make a mark on the center of the tread. The thumbtack held the tape in place because there was just one of me. Didn't do this on the Z but it worked on the '62 and I finally got the steering wheel straight and the toe-in just right for essentially $0.
Old Dec 24, 2008 | 02:19 AM
Gtpguy's Avatar
Nice idea.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Brake_L8
Jan 20, 2015 09:44 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
siguy
Nov 27, 2014 10:07 AM
