ABS INOP and LOW TRAC light
Old Apr 11, 2005 | 12:09 PM
Z28_Pilot's Avatar
Question ABS INOP and LOW TRAC light
Hey Gang,
I did a search for this but didn't find any real good answers, so I was wondering if anyone has any insight on this.
Once in awhile(at least once or twice everytime I drive the car) when I get on the brakes, my LOW TRAC light comes on and it feels like I'm letting off the brakes, it doesn't pulsate or anything, just feels like I'm letting off which gets kinda scary coming up behind traffic at a stoplight! the ABS INOP light usually comes on after that, but sometimes comes on independantly. If anyone has a good idea what this is I would love to hear it.
Thank-you in advance,
Z28_Pilot
Old Apr 11, 2005 | 12:36 PM
Dave '97 Z28 M6's Avatar
Re: ABS INOP and LOW TRAC light
You might have a bad/malfunctioning wheel speed sensor. Go to a dealer and have them scan the computer - there will probably be a fault code registered that will tell you what the problem is... or where to start looking at least.
Old Apr 11, 2005 | 02:28 PM
gsewell_uk's Avatar
As a possible quick fix, take off the front wheels and disconnect ABS sensor and reconnect it a few times on each side to make sure that the contacts are clean.
Old Apr 11, 2005 | 02:42 PM
Z28_Pilot's Avatar
Thank you for the replies.......is it easy to clean the sensor on the differential?
Old Apr 11, 2005 | 10:59 PM
OBE1 95Z28's Avatar
I had this fixed under warranty; they said the sensor in the differential was dirty. You should be able to disconnect the electrical connector and then remove the sensor for cleaning.
Old Apr 12, 2005 | 01:46 AM
lt1aggie's Avatar
Originally Posted by Z28_Pilot
Hey Gang,
Z28_Pilot
http://web.camaross.com/forums/showthread.php?t=170822
i took all the sensors loose and hosed them down. it fixed the problem.
Old Apr 12, 2005 | 10:49 PM
Z28_Pilot's Avatar
Thank you!.....thats what I love about this forum, it can save you alot of money by not having to take it to the shop!....I'm gonna try cleaning the sensors when I get back into town tomorrow!
Old Apr 13, 2005 | 03:07 PM
Brent94Z's Avatar
Super Moderator
I had the same symptoms as you and did what I quoted above except I bent the pins to the side just a little to ensure a good connection. Problem never came back after this
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
Jan 23, 2015 01:13 PM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
